2. Understand gotos in Reachy 2
You can choose to follow our online documentation or to make your Reachy move by following the notebook n°2.
Gotos methods
ReachySDK for Reachy 2 offers you methods to make movements with the arms and head, controlling the target position in several ways, choosing the duration of the movement, or even the interpolation mode. We called them Goto.
Those methods work the same way on different robot’s parts, such the arms, the head or the mobile base.
goto() function is not designed for high-frequency control. It is meant to move the robot to a specific target position—whether in joint space or Cartesian space—with a smooth, time-based trajectory.If your goal is to continuously adjust the robot’s position or follow a live trajectory, a dedicated method for high-frequency control is introduced in 7.Record and replay trajectories! ⚡🤖
The methods to use in order to control the robot are:
- for the arms :
goto(): depending on the parameter entered, you can control either :- the joint value of each joint in degrees : list of 7 values (joint space)
- the end-effector position in the robot frame of reference : 4x4 homogeneous matrix (cartesian space)
translate_by()androtate_by(): you can translate or rotate the position of the end-effector in space, in robot frame or gripper frame.
- for the head :
goto(): depending on the parameter entered, you can control either :- the joint value of each head joint in degrees : list of 3 values (joint space)
- the head orientation in the robot frame : quaternion (cartesian space)
⚠️ between the joint and cartesian spaces, there is a 10-degree difference in pitch : to have the head looking forward, in joint space you have to put rpy = [0,10,0] whereas in cartesian space, it’s the equivalent of [0,0,0].
look_at(): you control the head by giving a point in the robot coordinate system the head will look atrotate_by(): you can rotate the head in relation to its current position, by setting roll, pitch and yaw values in degrees, either in relation to the robot’s frame of reference or to the head.
- for the mobile base:
goto(): you control the mobile base by giving a position to reach in the odometry frame of the mobile base
Grippers and antennas also support goto commands:
- for the grippers:
goto(): you control the position or opening of the gripper
- for the antennas:
goto(): you control the position of the antennas
The following tutorial only shows examples for the arms, head and mobile_base, but most of the description is also true for the goto commands on the grippers and antennas.
Goto commands - arms and head
A goto command can be sent on parts:
- reachy.l_arm
- reachy.r_arm
- reachy.head
It can also be sent to grippers as antennas, as mentioned earlier:
- reachy.r_arm.gripper
- reachy.l_arm.gripper
- reachy.head.r_antenna
- reachy.head.l_antenna
It is defined by 3 parameters:
- a target, which can be either a joint commands (as a list of 7 articular degree values for the arms and 3 for the head, and a single float for grippers and antennas), or a cartesian command (for the arms and head only).
- a duration, in seconds - set to 2 by default
- an interpolation mode, ’linear’ or ‘minimum_jerk’ - set to ‘minimum_jerk’ by default
Goto duration
You can give a custom duration for the execution of the movements, as shown in the examples above :
reachy.head.goto([20, 20, -10], duration = 3)
reachy.l_arm.goto([0, -10, 10, -90, 0, 0, 0], duration = 5)
# Doing:
reachy.l_arm.goto([0, -10, 0, 0, 0, 0, 0])
# will lead to the same result as:
reachy.l_arm.goto([0, -10, 0, 0, 0, 0, 0], duration = 2)Default duration is 2 seconds.
You cannot set a duration to 0 second. This will raise an exception in your code!
reachy.l_arm.goto([0, 0, 0, 0, 0, 0, 0], duration = 0) # raises an exceptiongoto(), as it’s not intended for rapid updates or real-time control loops.Goto interpolation mode
The goto methods generates a trajectory between the present position and the goal position. This trajectory is then interpolated at a predefined frequency (150Hz) to compute all intermediary target positions that should be followed before reaching the final goal position. Depending on the interpolation mode chosen, you can have a better control over speed and acceleration.
Two interpolation modes are available when sending a goto command:
- the linear interpolation mode
- the minimum-jerk interpolation mode
Both trajectories start and finish at the same point but don’t follow the same intermediate positions. The minimum jerk will slowly accelerate at the begining and slowly decelerate at the end. This makes the movements more natural.
You can specify the interpolation mode by setting the interpolation_mode argument when calling the method:
reachy.head.goto([20, 0, -10], interpolation_mode='linear')
reachy.l_arm.goto([0, -10, 10, -90, 0, 0, 0], interpolation_mode='linear')Default interpolation mode is minimum_jerk.
# Doing:
reachy.l_arm.goto([0, -10, 0, 0, 0, 0, 0], interpolation_mode='minimum_jerk')Note that there is a third interpolation mode for the arm, the elliptical one, that you will see in details in the next section.
Goto commands - mobile_base
The goto parameters for the mobile base are a little different, as you cannot ask the mobile base to reach a target position in a given time. Instead of trying to reach the given position in a given time, the robot will take as long as needed to reach its goal, or be interrupted by the timeout you can set as parameter.
The parameters are:
- the x target, in meters
- the y target, in meters
- the theta target, in degrees by default
- the distance_tolerance and angle_tolerance, to define how close to your target the robot must be to consider the target has been reached (optional)
- a timeout value, to stop the movement if the target hasn’t been reached after a certain amount of time (optional)
# Rotation to reach a 90-degrees-rotation around the odom coordinate system
reachy.mobile_base.goto(x=0, y=0, theta=90)Goto tolerances
You can modify the tolerances around the goal position you want to reach. Tuning the tolerances will modify the precision of the position at arrival, but also modify the time the mobile base will take before considering its movement over. You will learn more about these tolerances in the mobile_base tutorial.
Goto timeout
You don’t have any duration parameters to control the mobile base, but you can use the timeout to stop the mobile base goto after a certain amount of time. The movement is stopped if the target has not been reached after the duration of this timeout. In the case the target has been reached before the timeout is over, the timeout will have no impact.
# Set back the robot in position 0
reachy.mobile_base.goto(x=0, y=0, theta=0)
# Move forward by 30cm
reachy.mobile_base.goto(x=0.3, y=0, theta=0)If we print the current position of the robot once it has stopped, we can see it has reached the goal position:
print(f"x: {round(reachy.mobile_base.odometry['x'], 1)}")
print(f"y: {round(reachy.mobile_base.odometry['y'], 1)}")
print(f"theta: {round(reachy.mobile_base.odometry['theta'], 1)}")Let’s do the same movement by adding a timeout to the forward goto:
# Move forward by 30cm, with a timeout of 0.5 seconds
reachy.mobile_base.goto(x=0.3, y=0, theta=0, timeout=0.8)If we print the current position, we can see the robot was stopped before reaching the target:
print(f"theta: {round(reachy.mobile_base.odometry['theta'], 1)}")Default timeout is 100 seconds.
Goto execution
There are two important concepts to be aware of :
- gotos are stacked for a part (i.e. they run one after another),
- but each part is independent (i.e. a goto for the left arm will run in parallel with a goto for the right arm).
Gotos are non-blocking
It means you can send a goto command on different parts, it won’t wait for the movement to be executed on the first part to execute the other one, but will follow the timing of your code.
reachy.l_arm.goto([0, 0, 10, -90, 0, 0, 15], duration = 3)
time.sleep(1)
reachy.r_arm.goto([0, 0, -10, -90, 0, 0, -15], duration = 2)This sequence will take 3 seconds to execute, as the right arm will start its movement 1 second after the left arm has started its own movement. They will finish at the same time.
Gotos are stacked for a part
It means that you can send several goto commands on a part one after another without any delay, they will be played in this order, but will wait for the previous goto to be finished.
reachy.l_arm.goto([0, 0, 15, -90, 0, 0, 15], duration = 3)
reachy.l_arm.goto([0, 0, 15, -90, 0, 0, 15], duration = 3)This sequence will take 8 seconds to execute, as each movement on the left arm will wait for the previous before starting.
Nevertheless, you can still send goto commands to other parts.
reachy.l_arm.goto([0, 0, 15, -90, 0, 0, 15], duration = 3) #1
time.sleep(1)
reachy.l_arm.goto([0, -10, 0, 0, 0, 0, 0], duration = 2) #2
reachy.l_arm.goto([0, 0, 15, -90, 0, 0, 15], duration = 3) #3
reachy.r_arm.goto([0, 0, -15, -90, 0, 0, -15], duration = 2) #4This sequence will still take 8 seconds to execute:
- commands #1, #2 and #3 are sent to the left arm. They will be stacked on the left arm, and the
time.sleep(1)won’t have any effect . When received, command #2 will simply wait 2 seconds rather than 3 secondes in the previous example. - commands #4 is sent on the right arm, where no movement is processed. It will then start 1 second after command #1 has started, and will then be over approximatively at the same time.
The sequence execution order is #1, #4, #2, #3.
So how can a left arm goto wait for a right arm move? That’s simple using the parameter wait in goto functions !
Wait parameter
We can set the parameter wait = True in goto functions for the execution of the program to wait for the end of the movement before going on.
goto_1 = reachy.r_arm.goto([0, 5, -15, 0, 0, 0, -10], duration = 2, wait = True)
goto_2 = reachy.l_arm.goto([0, -5, 15, -90, 0, 0, 10], duration = 2, wait = True)The left arm move will start only at the end of the right arm one.
Goto state
For a specific goto, you may want to know its current state. Each gotos returns an id, that you can use to get information or cancel this movement. Store this id in a variable to be able to use it further.
You can get information on the goto given its id with 2 methods available at reachy’s level:
is_goto_finished(): return True if the movement is over, but also if it won’t be played because it has been cancelled for exampleget_goto_joints_request(): will return the joints goal positions sent to the part by the corresponding goto command
Let’s take an example:
goto_1 = reachy.l_arm.goto([0, 0, 0, -60, 0, 0, 0], duration = 3)
if reachy.mobile_base is not None:
goto_2 = reachy.mobile_base.goto(0.2, 0, 0)
time.sleep(1)
# Goto is currently being played
goto1_is_finished = reachy.is_goto_finished(goto_1)
print(f'After 1 second, goto 1 is finished : {goto1_is_finished}\n')
>>> False
time.sleep(3)
# Goto is now over
print(f'After 4 seconds, goto 1 is finished : {goto1_is_finished}')
>>> TrueWe then have the goto_1 for the l_arm :
print(f"Part: {reachy.get_goto_request(goto_1).part}")
print(f"Request: {reachy.get_goto_request(goto_1).request}")And the second one for the mobile base:
print(f"Part: {reachy.get_goto_request(goto_2).part}")
print(f"Request: {reachy.get_goto_request(goto_2).request}")
else:
print("Cell content ignored, no mobile_base is available")You get information on the part involved, the target joint values, the duration of the movement, and the interpolation mode.
Part execution state
As the sequence can become complex, you can get information for each part on its current status, to know which movement is being played and know which orders are waiting to be played. For each part, the following methods are available:
get_goto_playing(): will return the id of the currently played goto on the partget_goto_queue(): will return the ids of all stacked goto commands waiting to be played on the part
Those methods are called at the part level, to get info on the state of the part.
Let’s take an example.
# Write a sequence for the left arm
goto_1 = reachy.l_arm.goto([0, -15, 15, -90, 0, 0, 0], duration = 3)
goto_2 = reachy.l_arm.goto([0, -10, 0, 0, 0, 0, 0], duration = 2)
goto_3 = reachy.l_arm.goto([0, -15, 15, -90, 0, 0, 0], duration = 3)
print(f'goto 1: {goto_1.id}, goto 2: {goto_2.id}, goto 3: {goto_3.id}')
>>> goto 1: 45, goto 2: 46, goto 3: 47
# Goto #1 is currently playing
current_goto = reachy.l_arm.get_goto_playing()
print(f'current goto : {current_goto.id}')
print(f'l_arm queue length: {len(reachy.l_arm.get_goto_queue())} gotos waiting to be played.')
>>> current goto : 45
>>> l_arm queue length : 2 gotos waiting to be played. Goto cancellation
If you want to modify the queue of goto commands on a part, or interrupt the movement being played, you can cancel goto commands at any time.
Single goto cancellation
To cancel a single movement, currently playing or stacked in a part’s queue, use its id and call cancel_goto_by_id() from reachy. It will stop the robot at its current position.
goto_1 = reachy.l_arm.goto([0, 15, 15, -90, 10, 0, 0], duration = 3)
goto_2 = reachy.head.goto([30, 0, 0], duration = 3)
time.sleep(1)
reachy.cancel_goto_by_id(goto_1)Multiple gotos cancellation
To cancel all gotos at once, you can call the cancel_all_goto() methods.
This method can be called at the level you want to act, which can be either reachy or a specific part.
All gotos
For example, if you want to cancel all gotos on all parts:
# Send a sequence of gotos
reachy.head.goto([20, 30, -10], duration = 3)
reachy.l_arm.goto([0, 0, 0, -90, 0, 0, 0], duration = 3)
reachy.l_arm.goto([0, 0, 0, 0, 0, 0, 0], duration = 3)
time.sleep(1.5)
# Cancel all gotos
reachy.cancel_all_goto()
print(f"Length of l_arm goto queue : {len(reachy.l_arm.get_goto_queue())}")
>>> Length of l_arm goto queue : 0All movements are cancelled, even the movement stacked in the left arm queue which will never be played.
All gotos for one part
If you only want to cancel movement on the left arm:
reachy.head.goto([20, 30, -10], duration=3)
reachy.l_arm.goto([0, 0, 0, 0, 0, 0, 0], duration = 2)
time.sleep(1)
# Cancel gotos on left arm only
reachy.l_arm.cancel_all_goto()The movement on the head will continue, but all the movements of the left will be stopped and the left arm queue cleaned.
👏 Yes, you did it!
Understanding how goto() works is key to mastering how Reachy moves and behaves. Whether you’re controlling the arms, head, gripper, or mobile base, knowing how motions are stacked, when they end, how they can be interrupted, will unlock a whole new level of control.
Keep going—you’re ready for your first moves! 🚀🤖
