Each actuator has a unique name and UID. To access a specific actuator, you can use the attribute under the part you are using. We do not provide direct access to all actuators. For the arms, the following actuators are available:
fromreachy2_sdkimportReachySDKreachy=ReachySDK(host='10.0.0.201')# Replace with the actual IPreachy.r_arm._actuators>>>{'shoulder':<Orbita2don=Falsejoints=<OrbitaJointaxis_type="pitch"present_position=5.0goal_position=5.0><OrbitaJointaxis_type="roll"present_position=16.7goal_position=16.7>>,'elbow':<Orbita2don=Falsejoints=<OrbitaJointaxis_type="yaw"present_position=-6.41goal_position=-6.41><OrbitaJointaxis_type="pitch"present_position=-16.58goal_position=-16.58>>,'wrist':<Orbita3don=Falsejoints=<OrbitaJointaxis_type="roll"present_position=-17.29goal_position=-17.29><OrbitaJointaxis_type="pitch"present_position=1.54goal_position=1.54><OrbitaJointaxis_type="yaw"present_position=-41.39goal_position=-41.39>>,'gripper':<ParallelGripperon=Falsejoints=<GripperJointon=Falsepresent_position=57.57goal_position=57.57>>}
Because Orbita2d (shoulder and elbow) and Orbita3d (wrist) are parallel actuators, it often doesn’t make sense to control one motor of an actuator without controlling the other motors of the same actuator.
This is why actuators are, in most cases, the lowest degree of control we provide. Modifying compliance, torque or speed is not available at joint level.
To access a specific joint, you can either use reachy.joints which has each joint of the robot as an attribute or access it via the actuators it belongs to. For example, to access the right arm shoulder roll: reachy.r_arm.shoulder.roll.
First, connect to your Reachy.
fromreachy2_sdkimportReachySDKreachy=ReachySDK(host='10.0.0.201')# Replace with the actual IPreachy.r_arm.shoulder.roll<OrbitaJointaxis_type="roll"present_position=3.54goal_position=3.55>
Joints in Reachy are abstract elements that do not have a physical representation. A joint is controlled by several motors of the actuators. The only thing you can do at the joint level is read the present_position and send goal_position.
The goal_position attribute of a joint can be used to set a new joint’s target position to make it move. However, we recommend using the goto() method to move the motors, which provides better control of the joint’s trajectories.
Using goal_position will make the motor move as fast as it can, so be careful when using it.
Grippers are part of arms: this means that if the arm is turned on, so is the gripper. However, in most cases, the gripper is controlled independently from the rest of the arm.
To get access to a gripper, you have to go through the corresponding arm:
the joint space, which allows reading and writing directly the angle values of each joint of the arm
the cartesian space, which consists of controlling the end effector’s position and orientation in Reachy’s coordinate system
Both spaces are quite different, and we advise not to mix them if you are not familiar with the output.
In fact, values of the joint space are expressed in each actuator’s coordinate system (shoulder, elbow, and wrist), whereas commands in Cartesian space are expressed in Reachy’s coordinate system.
Reachy 2’s arm can be moved using the goto() method, which supports both joint space and Cartesian space commands. Depending on your needs, you can define target poses using a list of 7 joint values (joint space command) or a 4x4 matrix (Cartesian space command).
As described in the page Understand gotos in Reachy 2, there are several parameters you can modify to customize your goto() movement on the arm:
standard goto parameters:
duration(float) – Specifies the duration of the movement in seconds, which is 2 by default.
wait(bool) – If set to True, the method becomes blocking and waits until the movement is complete.
interpolation_mode(str) – Defines the trajectory profile used to reach the target. Available options are:
‘minimum_jerk’ (default) – Smooth motion with minimal jerk.
’linear’ – Straightforward, linear interpolation.
’elliptical’ – interpolation following the trajectory of an ellipse, available in cartesian space only (see arm specific goto parameters below).
joint space specific goto parameter:
degrees(bool) – Specifies if the angular value is in degree or in radians (default to degrees).
cartesian space specific goto parameters:
interpolation_space(str) – Determines how the motion interpolation is performed. It accepts two possible values:
‘joint_space’ (default): The interpolation is done independently on each joint, from its current position to its target position. This is a straightforward and efficient method, commonly used for most joint-based motions.
‘cartesian_space’ : The interpolation is performed in cartesian space, between the gripper’s current pose and its target pose. In this mode, the inverse kinematics (IK) solver is used to compute the intermediate joint configurations required to follow the cartesian path. ’elliptical’ interpolation mode is only supported in cartesian space interpolation.
arc_direction(for elliptical interpolation only) – Defines the orientation of the arc—that is, the direction in which the motion will “bulge” along the elliptical path. Can be “right”, “left”, “front”, “back”, “above” or “below”
secondary_radius(for elliptical interpolation only) – Defines the secondary radius of the ellipse — essentially, how far the motion will deviate from a straight line in the direction specified by arc_direction. If secondary_radius is not specified, the motion will follow a half-circle arc between the current and target poses.
Here’s a set of commented examples showcasing how to use goto() with Reachy 2’s arm, covering both joint space and Cartesian space, along with various parameters like duration, wait, interpolation_mode, and Cartesian-specific options like arc_direction and secondary_radius.
🦾 Example 1: Basic joint space motion
Move the right arm to a predefined joint configuration with the elbow bent at 90°.
right_angled_pose=[0,10,-10,-90,0,0,0]# angles in degreesreachy.r_arm.turn_on()reachy.r_arm.goto(right_angled_pose)
What it does: Moves each joint independently to reach the specified angles. No waiting or timing is specified, so the default duration (2 seconds) is used.
🦾 Example 2: Slower joint space motion with blocking behavior
What it does: Moves the arm to a pose with a slightly bent elbow and raised wrist over 3 seconds. The wait=True parameter makes the function blocking, so the script waits for the movement to complete before continuing.
What it does: Sends the same kind of joint space command, but the angles are given in radians.
🦾 Example 4: Cartesian space motion with default interpolation
importnumpyasnp# Move the gripper to a new 3D position and orientation (4x4 matrix)target_pose=np.array([[0,0,-1,0.3],[0,1,0,-0.4],[1,0,0,-0.3],[0,0,0,1]])reachy.r_arm.goto(target_pose)
What it does: Moves the end effector to the given pose in Cartesian space using the default interpolation mode (minimum_jerk) and joint space interpolation.
🧠 To better understand how to construct a correct 4x4 target_pose matrix for Cartesian movements, check out the next page: Use arm kinematics.
🦾 Example 5: Cartesian interpolation in Cartesian space
What it does: Instead of interpolating each joint directly, this uses Cartesian interpolation to smoothly move the gripper between poses, with IK computing intermediate joint positions.
🦾 Example 6: Elliptical interpolation with upward arc
What it does: Moves the gripper along a leftward elliptical arc, with a custom arc radius of 10 cm from the straight line connecting the start and end pose.
Simplifying Cartesian motions with translate_by() and rotate_by()!
When working in Cartesian space, you often need to compute a new 4×4 pose matrix to describe where you want the gripper to move. Manually building these matrices can be complex and error-prone—especially when dealing with rotations and different coordinate frames.
To make this easier, Reachy 2 SDK provides built-in helper functions:
translate_by():
This function allows you to move the gripper relative to its current pose by specifying a translation vector in meters.
This moves the gripper 10 cm upward in Reachy’s base coordinate frame (positive z-axis of the robot).
rotate_by():
Similarly, rotate_by() lets you apply a relative rotation to the gripper’s current pose, using angles (in degrees by default, but you can use radians with degrees=False).
These functions compute the necessary target pose behind the scenes and send the appropriate goto() command for you — making it easier to chain natural translations or rotations without needing to manipulate matrices directly.
Both translate_by() and rotate_by() are goto-based functions. This means:
They follow the same internal mechanisms as goto()
They are stackable: you can queue multiple motions
They are cancelable: you can interrupt them using the appropriate cancel method
They support most standard goto() parameters
Important notes on relative behavior These motions are computed relative to the target pose of the most recent goto() command — whether that command is currently executing or is queued.
If no goto() command is playing, the movement will be computed relative to the gripper’s current pose.
⚠️ Warning: Effect of cancelled goto If the last goto() command is canceled after being issued, any subsequent translate_by() or rotate_by() calls will still compute their motion based on the original target of the canceled command, not the actual gripper position at cancellation time or the previous goto(). This means:
The computed motion remains unchanged even if the prior goto() was interrupted.
The final pose will still be relative to the intended (but not reached) target of that canceled movement.
using its own goto() functions for configurable, queued motions
or with simpler, immediate commands such as open(), close(), and set_opening() (which are not goto()-type functions).
Note that there is a smart gripper control that will stop the gripper from reaching any closed / partially-closed position if an object is detected while closing.
This method allows you to send a target position to the gripper and provides several parameters to customize its behavior, already seen in the page 2. Understand gotos in Reachy 2:
duration(float) – Specifies the duration of the movement in seconds, which is of 2 seconds by default.
reachy.r_arm.gripper.goto(50,duration=3)
For example this call will block until the gripper has fully completed its movement:
reachy.r_arm.gripper.goto(50,wait=True)
interpolation_mode(str) – Defines the trajectory profile used to reach the target. Two options are available:
This command moves the gripper with a linear trajectory instead of the default smooth minimum jerk motion:
By default, the target value is interpreted in degrees. However, you are not limited to degrees—you can also choose to:
Use radians by passing degrees=False:
reachy.r_arm.gripper.goto(0.87,degrees=False)
Use a percentage of opening with percentage=True:
reachy.r_arm.gripper.goto(50,percentage=True)
This gives you flexible control over the gripper, depending on how you prefer to express its position: in degrees, radians, or as a percentage of full opening.
To open the grippers, call the open() method on the desired gripper. It will open it entirely:
reachy.r_arm.gripper.open()
To close the grippers, call the close() method on the desired gripper. It will close the gripper with the appropriate value, which means it will be entirely closed if there is no object to grasp, or set a suitable value if an object has been detected in the gripper during the closing:
reachy.r_arm.gripper.close()
⚠️ Important: These functions are not goto-type calls
Be aware that the open() and close() methods controlling the gripper are notgoto()-type functions. This means:
They are not stacked like goto() calls.
They cannot be made blocking using a wait=True parameter.
When you call one of these functions, it is executed immediately, regardless of any goto() motions that may already be queued for the gripper.
As a result, it is strongly recommended to avoid mixing goto() calls and non-goto() commands, as this may lead to unpredictable behavior.
🧩 Making open() / close() functions blocking
These actions are non-blocking, meaning that the rest of your program won’t wait for the action to complete. But you can manually wait for their execution to finish using the is_moving() method:
reachy.r_arm.gripper.close()# Wait for the gripper to finish openingwhilereachy.r_arm.gripper.is_moving():time.sleep(0.05)reachy.r_arm.gripper.open()
The opening value corresponds to a percentage of opening, which means:
0 is closed
100 is open
You can control the opening of the gripper using the set_opening() method.
Send your custom opening value, between 0 and 100, to the gripper with:
reachy.r_arm.gripper.set_opening(50)# half-opened
Like open() and close() functions, these actions are not goto-type calls, so non-blocking, meaning that the rest of your program won’t wait for the action to complete (see open() / close() section for more explanations). You can use the boolean is_moving() to make it blocking:
The default parallel gripper is a specific actuator with a single joint, so you can directly read its present_position doing:
reachy.r_arm.gripper.present_position>>>50.04
You can also read the opening of the gripper, still as a percentage (0 is closed):
reachy.r_arm.gripper.get_current_opening()>>>20# almost closed# Or directly:reachy.r_arm.gripper.opening>>>20# almost closed
🧭 We’ve mentioned it a lot throughout this page… But now it’s time to dive deeper into the world of arm kinematics.
Understanding how Reachy’s arm moves in 3D space—how joint angles, forward kinematics, and poses all come together—is a crucial step toward control of the robot motion.
Buckle up. The journey into kinematics starts on the next page! 💪
