7. Record and replay trajectories
So far, you’ve seen how to use goto() to move Reachy to specific positions. While this is perfect for high-level actions, it’s not meant for high-frequency control, like following a fast-changing target, reacting continuously to sensor input, or replaying smooth demonstrations with precision.
That’s where recording and replaying trajectories comes in.
Use of send_goal_positions()
When you want Reachy to follow a continuous trajectory—whether captured from teleoperation, a learned model, or an external controller—you need something more responsive than goto().
The send_goal_positions() method sends the specified goal positions to all the joints you provided a goal_position for:
- It allows you to send joint positions frame by frame, at high frequency (e.g. 100 Hz).
- It gives you low-latency, real-time-like control of the robot’s motion.
Unlike goto(), this method does not interpolate between positions, and sends the goal_position immediately.
⚠️ Important: Use only for continuous trajectories
send_goal_positions(), Reachy will attempt to move to the goal position as fast as it can. This means you must only use it to send small, continuous steps, where each goal is close to the current position.If the gap between the current and target joint positions is too large, this can result in unsafe movements or emergency freeze of the robot.
Examples of reachy.send_goal_positions() usage
🦾 Example 1: Set all joints to 0°
Before calling send_goal_positions(), you must manually set goal_position for each joint you want to control.
⚠️ Do not play this example on a real robot
# Set all joints to position 0
for joint in reachy.joints.values():
joint.goal_position = 0
# Send the command to the robot
reachy.send_goal_positions()🦾 Example 2: Play a sine wave on r_arm elbow
This example simulates sending high-frequency control to create a smooth trajectory:
import time
import math
# Parameters
frequency = 0.5 # Hz, so one full movement every 2 seconds
duration = 5 # seconds
update_rate = 0.01 # 100Hz
start_time = time.time()
while time.time() - start_time < duration:
t = time.time() - start_time
angle = -25 + 25 * math.sin(2 * math.pi * frequency * t) # Range: 0° to -50°
reachy.r_arm.elbow.pitch.goal_position = angle
time.sleep(update_rate)Recording a trajectory
In the following examples, we will assume that you are already connected to your robot and know how to control individual joints.
To record a trajectory, we will simply get the current positions of individual motors at a predefined frequency, typically 100Hz. We will first define a list of motors that we want to record. In this example, we will only record the joints from the right arm, but you can similarly record a single joint or all joints of the robot at once.
# assuming we run something like this before:
# reachy = ReachySDK(host='10.0.0.201')
recorded_joints = [
reachy.r_arm._shoulder.pitch,
reachy.r_arm._shoulder.roll,
reachy.r_arm._elbow.yaw,
reachy.r_arm._elbow.pitch,
reachy.r_arm._wrist.roll,
reachy.r_arm._wrist.pitch,
reachy.r_arm._wrist.yaw,
]Now let’s define our frequency and record duration:
sampling_frequency = 100 # in Hz
record_duration = 5 # in sec.Our record loop can then be defined as such:
import time
trajectories = []
start = time.time()
while (time.time() - start) < record_duration:
# Here we get the present position for all recorded joints
current_point = [joint.present_position for joint in recorded_joints]
# Add this point to the already recorded trajectories
trajectories.append(current_point)
time.sleep(1 / sampling_frequency)If you want to record a demonstration on the robot, first make sure the robot is compliant. Then, put it in the starting position. Run the code, and start moving the robot. After 5 seconds, the loop will stop and the movements you have made on Reachy will be recorded.
Depending on your use case, you can define another duration. You can also choose not to use a specific duration but instead use start and stop events to control recording. In such cases, the easiest way is probably to run the loop within a thread or an asynchronous function so it can run in the background.
Visualize your recordings
The trajectories you recorded can be converted to a numpy array for more complex processing:
import numpy as np
traj_array = np.array(trajectories)If you are familiar with matplotlib, you can also plot it via:
from matplotlib import pyplot as plt
plt.figure()
plt.plot(trajectories)Replay a recorded trajectory
Replaying the recorded trajectory basically uses the same loop but sets the goal position instead of reading the present position.
Before actually replaying the trajectory, there are a few key points to consider:
- First, make sure the joints you are going to move are stiff.
- Then, if the arm is not in the same position as the one you used as a starting position for your recording, the beginning of the replay will be abrupt. It will try to go to the starting position as fast as possible.
To avoid this, you can use the goto function to first go to the initial point of your trajectories:
# Set all used joints to stiff mode
reachy.r_arm.turn_on()
# Create a dict associating a joint to its first recorded position
first_point = dict(zip(recorded_joints, trajectories[0]))
# Go to the start of the trajectory in 3 seconds
reachy.r_arm.goto(first_point, duration=3.0)Now that we are in position, we can actually play the trajectory. To do this, we simply loop over our recordings, set the goal position of each joint, and then send all the commands at the same frequency:
import time
for joints_positions in trajectories:
for joint, pos in zip(recorded_joints, joints_positions):
joint.goal_position = pos
reachy.send_goal_positions(check_positions=False)
time.sleep(1 / sampling_frequency)The
check_positionsparameter is used to verify that the goal positions have been reached after the command has been sent and that there have been no problems with unreachable positions. This process can take time and slow your replay. Since this is a recording, all poses are necessarily reachable, so there’s no need to waste processing time on this check.
🏅 You’re now a movement expert on Reachy 2.
There’s no secret left when it comes to making the robot move with precision and style.
But movement alone isn’t enough—if you want Reachy to interact with the world, it needs to see and hear what’s around it.
🎥 Up next: Learn how to use Reachy’s cameras and open the door to perception-driven interaction!
