8. Get images from cameras
On this page
You can choose to follow our online documentation or directly see images from your Reachy by following the notebook n°6.
This section assumes that you have gone through the Hello World guide to learn how to connect to the robot.
Reachy 2 has two types of cameras:
- Teleop cameras, which include left and right cameras located in Reachy’s head, used for teleoperation.
- Depth camera, equipped with a depth sensor, located in Reachy 2’s torso, primarily useful for manipulation tasks.
Each camera can be accessed separately through reachy.cameras. Teleop cameras have left and right views, with the sides defined from Reachy’s perspective, while the depth camera provides a left (i.e., mono RGB) and depth view. To specify the view you want to get a frame from, you will need to import CameraView:
from reachy2_sdk.media.camera import CameraViewGet images
First, connect to your Reachy:
from reachy2_sdk import ReachySDK
reachy = ReachySDK(host='10.0.0.201') # Replace with the actual IP
reachy.cameras
>>> <CameraManager initialized_cameras=
<Camera name="depth" stereo=False>
<Camera name="teleop" stereo=True>
>The list of initialized cameras should include both teleop and depth cameras.
For each one of the two cameras, you must call the get_frame() function whenever you want to retrieve an image.
Teleop camera
RGB images
To get images from the left and right teleop cameras along with their timestamps:
l_frame, l_ts = reachy.cameras.teleop.get_frame(CameraView.LEFT)
r_frame, r_ts = reachy.cameras.teleop.get_frame(CameraView.RIGHT)By default, if no camera view is specified, the left camera is used.
To display the captured frame using PIL:
from PIL import Image
Image.fromarray(l_frame[:, :, ::-1])Camera parameters
The intrinsic camera parameters, as defined here, are available:
height, width, distortion_model, D, K, R, P = reachy.cameras.teleop.get_parameters(CameraView.LEFT)Extrinsic parameters (the transformation from Reachy’s origin to the camera’s frame) are also available:
T_cam_reachy = reachy.cameras.teleop.get_extrinsics()
>>> array([[-8.20152401e-04, -9.99999365e-01, -7.72635108e-04,
3.25965794e-02],
[ 2.65685388e-03, 7.70453615e-04, -9.99996174e-01,
1.80999522e-01],
[ 9.99996134e-01, -8.22202042e-04, 2.65622030e-03,
-3.56420275e-02],
[ 0.00000000e+00, 0.00000000e+00, 0.00000000e+00,
1.00000000e+00]])Depth camera
The depth camera operates similarly to the teleop camera but captures additional data. It is an RGBD camera, providing both RGB images and depth information.
RGB image
You can retrieve RGB images using get_frame():
rgb_frame, rgb_ts = reachy.cameras.depth.get_frame()To display it using PIL:
Image.fromarray(rgb_frame[:, :, ::-1])Depth information
Retrieve depth data using get_depth_frame():
depth_frame, depth_ts = reachy.cameras.depth.get_depth_frame()
Image.fromarray(depth_frame[:, :, ::-1])Camera parameters
The intrinsic camera parameters, as defined here, are available as follows:
height, width, distortion_model, D, K, R, P = reachy.cameras.depth.get_parameters()
>>> (720,
1280,
'rational_polynomial',
array([ 6.69530872e-03, -5.04049882e-02, 3.94786854e-04, 6.92563481e-05,
3.36577334e-02, 0.00000000e+00, 0.00000000e+00, 0.00000000e+00]),
array([[692.074646 , 0. , 637.12384033],
[ 0. , 691.86395264, 358.03106689],
[ 0. , 0. , 1. ]]),
array([[1., 0., 0.],
[0., 1., 0.],
[0., 0., 1.]]),
array([[692.074646 , 0. , 637.12384033, 0. ],
[ 0. , 691.86395264, 358.03106689, 0. ],
[ 0. , 0. , 1. , 0. ]]))Extrinsic parameters (the transformation from Reachy’s origin to the camera’s frame) are also available:
T_cam_reachy = reachy.cameras.depth.get_extrinsics()
>>> array([[ 1.11022302e-16, -1.00000000e+00, 5.55111512e-17,
9.98900000e-03],
[-7.43144825e-01, -1.11022302e-16, -6.69130606e-01,
6.23442696e-02],
[ 6.69130606e-01, 5.55111512e-17, -7.43144825e-01,
-4.88122743e-03],
1.00000000e+00]])📸 That’s it for the cameras!
Now that Reachy can see, let’s give it the power to hear and speak.
🎧 Up next: Learn how to use audio with your robot—to record sound, play audio files, and make Reachy even more interactive!
