9. Play and record sounds
You can choose to follow our online documentation or to make your Reachy move by following the notebook n°7.
Audio presentation
Reachy 2 is equipped with:
- 🎤 Two microphones, one in each antenna.
- 🔈 One speaker, located in the torso.
The Audio API allows you to:
- Upload and manage sound files.
- Play and stop audio.
- Record using the microphones.
⚠️ Note: Audio files are stored in a temporary folder on Reachy’s internal computer and are deleted at each reboot. There’s no persistent storage yet. The file management is very basic, allowing just a list of files in a single folder.
File Management
Before doing anything with audio, make sure you’re connected to Reachy as usual:
from reachy2_sdk import ReachySDK
reachy = ReachySDK(host='your-reachy-ip') # Replace with your robot’s IPList available audio files
Let’s start by listing the available audio files on the robot:
reachy.audio.get_audio_files()If you’ve just started working with Reachy, this list might be empty.
Upload an audio file
Reachy supports .wav, .mp3, and .ogg files. To upload a sound from your computer:
reachy.audio.upload_audio_file('/path/to/sample-1.ogg')
reachy.audio.upload_audio_file('/path/to/sample-2.wav')After uploading, you should see them listed:
reachy.audio.get_audio_files()Remove an audio file
Don’t need a sound anymore? You can delete it like this:
reachy.audio.remove_audio_file('sample-2.wav')
reachy.audio.get_audio_files()This will remove it from Reachy’s internal audio folder.
Playing audio on Reachy
Play an uploaded file
Once your file is uploaded, you can play it through Reachy’s speaker:
reachy.audio.play_audio_file('sample-1.ogg')Stop playback
If you need to stop the audio mid-play:
reachy.audio.stop_playing()This will immediately cut off the sound.
Recording audio with Reachy’s microphones
Recording is just as simple! You can have Reachy record from its stereo microphones.
⚠️ Note: For now, only
.oggformat is supported when recording.
Record audio
To start a 5-second clip recording in the background, with the file name tutorial:
reachy.audio.record_audio('tutorial.ogg', duration_secs=5)The duration of the recording, in seconds, must be set.
The file will be stored on Reachy.
You can stop a recording early:
reachy.audio.stop_recording()Access or play back the recorded audio
Once recorded, the file is available in the same temporary audio folder:
reachy.audio.play_audio_file('tutorial.ogg')Download the recording to your computer
If you want to save your recording:
reachy.audio.download_audio_file('tutorial.ogg', '/your/local/path/tutorial.ogg')This copies the file from Reachy’s system to your local machine, at the given path.
You can now chain audio playback with gestures or head motions for expressive sequences!
And…
🎉 Congratulations!
You now know all the basics of Reachy’s SDK—movement, perception, audio, and more.
Now it’s time to level up.
Let’s move on to implementing complex behaviors in the Advanced tutorials! 🚀🤖
