Title here
Summary here
The mobile base is controlled by the joysticks on each controller:
A message will appear if an obstacle is detected by the lidar: if you approach it slightly, the mobile base will slow down, and if you reach the maximum limit distance, the mobile base will stop.
If you wish to change the safety distances, please refer to the section on the mobile base in the Client SDK.
